Issues gluing Sapele
http://www-.luthiersforum.com/forum/viewtopic.php?f=10123&t=41197
Author:  andyjs999 [ Thu Aug 22, 2013 9:54 am ]
Post subject:  Issues gluing Sapele
Very weird....I'm building my first electric guitar, but I've been working with wood for a long time. I'm putting a 1/4 sapele face on the back and for some reason I'm having trouble gluing the book-matched pieces together. I've always used Titebond, but for some reason the joint won't hold and I can actually just pull the two pieces apart after letting it dry for about 24 hours. Has anyone else had this issue? Any suggestions? Thanks!
Author:  Chris Pile [ Thu Aug 22, 2013 10:56 am ]
Post subject:  Re: Issues gluing Sapele
How old is your Titebond?
Author:  andyjs999 [ Thu Aug 22, 2013 11:10 am ]
That is a good question. Probably less than 8 months old. It's Titebond II and it's been working fine on maple.
Author:  B. Howard [ Thu Aug 22, 2013 11:23 am ]
Sapele is usually not a problem to glue.....try cleaning your freshly joined edges with some DA prior to glue up. Perhaps this piece has a high resin content, that should take care of that.
Author:  Nick Royle [ Thu Aug 22, 2013 11:26 am ]
Silly question, Brian: What is DA? I'll be needing some for gluing Teak soon, I'm sure, if it helps with high resin/oil content.
Cheers,
Nick
Author:  andyjs999 [ Thu Aug 22, 2013 11:32 am ]
Denatured Alcohol.
Thanks, Brian that is a good idea. I will try that and re-post.
Author:  Nick Royle [ Thu Aug 22, 2013 11:40 am ]
I knew it was a silly question. What's 2+2 again? :)
Author:  andyjs999 [ Thu Aug 22, 2013 11:49 am ]
No silly questions! Just don't drink the DA!
Author:  Nick Royle [ Thu Aug 22, 2013 11:54 am ]
Not even with a mixer? :)
Author:  Stuart Gort [ Thu Aug 22, 2013 2:47 pm ]
There are no silly questions...just silly assumptions.
When joining Sapele I only use Titebond and have never had problems.
I can only think of two things...bad glue...or contaminated surfaces.
Author:  andyjs999 [ Fri Aug 23, 2013 1:14 pm ]
Third attempt on this glue up. Re-jointed, wiped down with DA, and tight clamps. Just a little bit better but still able to bend the joint. I think it's time to give up on this billet! I'm pissed that I already planned to add the thickness on the back and planed down my mahogany body. Now I need to find a maple cap for the back.
Author:  JEguitars [ Fri Aug 23, 2013 3:46 pm ]
Next time only try to use Titebond I, with the red label. The other one should have held, but you probably didn't have a clean joint and not enough surface to glue. I know titebond II is not recommended by all the luthiers I have ever seen talk about it.
Author:  B. Howard [ Sat Aug 24, 2013 6:09 pm ]
I agree, titebond 1 is preferred for this game. But I have glued more Sapele than I can remember with the type 2 without any problems.
Author:  andyjs999 [ Wed Aug 28, 2013 1:41 pm ]
Thank you JEguitars and everyone else. I re-jointed AGAIN and used Titebond Original and it worked. Thank you for the help everybody!
